Dell Optiplexx 9010 SFF Maximum Capacity HDD Supported?
Found the basic specs straight away:
https://www.dell.com/en-au/work/shop/business-pcs-desktop-computers/new-optiplex-9010/spd/optiplex-9010
The SFF models typically only have enough room for 1 HDD. Generally a BIOS update for older machines will allow you to have high capacity drives if required as long as they fit into the case. If it is the SFF model then it uses only a single 3.5" drive (laptop drive) however you can put an SSD in there, just not a full size HDD.
Reference Guides, Manuals, and Links to the latest drivers
https://www.dell.com/support/home/au/en/aubsd1/product-support/product/optiplex-9010/manuals
Brad
