Welcome to the Aussie Arcade forums. For 15 years Aussie Arcade has been in the forefront on promoting the Pinball and Video Arcade hobby. Other topics include repair and restoration of Pinball and Arcade machines, retro computers and consoles, jukeboxes and much more.
Aussie Arcade is also home to the Mame Gaming League and Visual Pinball League two great competitions you can participate in.
You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today!
If you have any problems with the registration process, account login or need to reactivate an old account please contact us.
*IMPORTANT* If you have not received your verification email please check your anti spam settings and junk mail folders before contacting the Admin. The verification email can take up to 10-15 minutes to arrive. *IMPORTANT* If you are having trouble resetting your password with the link provided use the code instead. Some email clients do not format the link correctly. The code must be used before the link to work, if you have already used the link it will invalidate the code and you will have go through the process again.
OK Guys I have this llast unit available....
For Aussie Arcade Members I will chop of $100...
Its fully set up ready to go.
Ideally the setup would be used with a PC system and MAME.
The monitor is a VGA monitor and uses a standard VGA cable so easy to connect to the PC.
JAMMA wiring - PSU - 6 Buttons - 4way 240volt power board...
I just paid a fortune for one of these thinking it was a tri-sync. I didn't realise it was SVGA ONLY. It looks ok(ish) in 800x600@60Hz and 640x480@60Hz but 15kHz and 25kHz modes don't work at all. It's a very bad choice if you want an authentic MAME experience. Maybe it's ok for people that want a "one size fits all" or "near enough is good enough" solution.
EDIT: It turns out that these are dodgy dual-focus LG TV tubes with an old PC SVGA monitor chassis hooked up. The geometry is terrible since the combination is not designed to work togetther at all. DODGY!!
Also, the rear mains panel was arcing due to a bad solder joint that had been bogged up with silicon. The coin mech didn't work at all and it was covered in screwdriver scratches looking as if somebody had been messing with it for hours.
Most people wouldn't have the balls to sell something like this (especially as "new")
I dunno what the problem is.... I was never contacted about any issues... the pics of the cabinet clearly show its working OK. And clearly states its VGA plug and screen and suitable for PC systems. The geometry looks fine to me in the pics.....
As for the coinmech you need to program it first before it works and the scratches are on all the units I have its from the coin holders they are in.
The add also says its the last one and it is new... as in unused... it still has warehouse dust and the like from over a year of storage on some of it.
