Making a few B&W LAI XY Vector PCBs
I am going to make PCBs and Monitor adjustment board for the 20" B&W XY LAI Chassis (LAI-KZ-20XYB)
Pot board is designed
It will mount on the bracket that holds the heatsink
Board
http://www.dsbelec.iinet.net.au/LAI_Pot_Board_FINAL-a_Dez-sm.jpg
How it will look / mount
https://www.amazingarcading.com.au/LAI_POT_BOARD-FIT-sm.jpg
And a copy of this
https://www.amazingarcading.com.au/LAI_Vector_PCB05.jpg
Pots board include
  • X Gain
  • Y Gain
  • B Adj
  • Brightness
  • Contrast
I need 4 or 5 of these
Pic of the pcb file almost finished
https://www.amazingarcading.com.au/lai_sAMPLE-04-SM.jpg
Let me know if you want one 🙂
Pics of actual prototype
https://www.amazingarcading.com.au/LAI_Proto_01-sm.jpg
https://www.amazingarcading.com.au/LAI_Proto_02-sm.jpg
Edited by dezbaz
  • 5 months later...
This has been promoted to active. Starting to convert to pcb file ready to make the required Gerber files
I am about a week into it, nothing too taxing about this one I must say. :cool:
Hmmm, I have an upright Asteroids that I would like to keep running in good condition for as long as possible, it's fine ATM, but for $30 to help future proof it I think I would buy one of these. I'm assuming it plugs in as a daughter board and takes over from the original adjustment pots?
Hmmm, just clicked on the pic, that looks nothing like mine, I don't think mine is a LAI, I got it from Visy who imported it from USA, too tired to research tonight :sleep
Your's will be Atari, LAI's will have the family logo on the marquee and the sideart
Still going on these
Starting to add the top layer silk screen, and have decided to add the values of the resistors.
The 14" screens had some different values, so I will think of a way to allow for that (Maybe add a key/legend on the board, you can refer to when assembling)
http://www.dsbelec.iinet.net.au/LAI-PCB_Sample_May12-sm.jpg
I won't be doing a prototype, just a main run, as the tooling cost is high. Might do a run of 10 to 15 of them only, I think
that looks familiar........hahaha
Yep, I will still use your creation mate
I am working on a proto that uses the HV from an amplifone Colour, and the deflection from the LAI board, so yours is the contender for the job
---------- Post added at 05:37 PM ---------- Previous post was at 05:35 PM ----------
So you could feasibly use a regular colour TV Tube in a BW vector game
More IDs done now
Notes done as mentioned earlier
Different type of triangulation used on a few transistors so they are soldered in more stable
http://www.dsbelec.iinet.net.au/LAI_Sample-02-sm.jpg
There are a lot of components on this sucker. I have removed about 12 components not needed on the 14" or 20" and added a few aftermarket pots too. They could be preset X & Y size pots
We will see
That looks spot on Dez! I have never had a board made with an angled side (or anything other than a regular rectangle for that matter).
Was this an issue? Did you have to specify anything or just supply Gerbers with an angle on the edge?
All I did was "place polygon", then right click the shape and select "define as board outline"
Here is what it looks like on the gerber viewer
http://www.dsbelec.iinet.net.au/Gerber_View1-sm.jpg
So the PCB maker will see the angle correctly, and should be cut like that
