Restoration Dos and Don'ts
  • Restoration Dos and Don'ts
    I was wondering if there was a list of Dos and Don'ts when restoring a cab?
    I've got two dedicated MK cabs (MK1 and MK2) both in need of work. One side of the CP box has suffered water damage and has blown out. The T-mold appears to be holding the piece together. I'm trying to work out if I just remove the piece and replace it with a new painted piece. or should I try and try and keep the original laminate piece and just hollow it out and refill the centre?
    Are there any guides for resurrecting/restoring plywood laminates?
    In regards to artwork, what are people's views on replacing them? Should you keep the original for authenticity, or is a repro from Game on Grafix seen as acceptable?
    These are my first cabs, and would hate to be responsible for an arcade faux pas.
    Hi
    It depends on how bad things are
    Are you considering filling in the T-Mold Slot?
    Some guys have glued it in. It also depends on your background IE skills etc
    Pics would help if possible
    Regards
    Dez
    DSB Electrical
    DSB Electrical Facebook
    VAPS
    Vector Monitor Repro Parts
      what if boards are rare as shit and expensive is installing a multiboard with the game a option
      just curious too
        I'd like to keep the T-molding as it really does make a cab. I was thinking I could remove the old plywood, 'refill' it with a new piece of board, reattach the laminate, reroute the piece then reuse the t-molding.
          Hi Joc
          Your poor old control panel is in a very sad shape mate (as you know, no doubt)
          Personally if it was me I would remake them sides, but it really comes down to what type of woodwork skills you have and what power tools too.
          I see the red sides are warped, so you probably would not be able restore that with glue or filler.
          Any questions please ask
          Regards
          Dez
          DSB Electrical
          VAPS
