My first upright - some expense spared
  • My first upright - some expense spared
    I got an upright cabinet on geebay (who ended up being an AA member Pommie Paul who is a real nice guy) and after close inspection realised it wasnt going to be one i would probably keep for a long time (cabinet pretty average) so went with the easiest and cheapest option to do a pretty good tart up of the old girl and 1 week was the limit on a budget with quality in mind where it mattered.
    so, after asking about the monitor in another thread, i figured i was missing an important part of the original wiring harness, so out it all come just leaving a bare cab and monitor slide (which i was going to reuse).
    i had a 21" monitor that ive had for maybe 8-10 years i guess and have been looking for a reason to replace it (it still has such a nice picture) so out of the case came the mitsubishi diamond pro and after getting it stripped down to 3 wires holding it all together decided to backpedal and put it back together in its chassis and make a new slide to suit and adjust the whole frame accordingly to be able to flip it from horizontal to vertical later as required (it was going to be a horizontal mame, but after reading another thread, they just dont give enough elbow room for a fighter so its vertical for now using the 48 in 1 out of the cocktail cabinet while i get around to fitting the 20" lcd in it and a 60 in 1 can go in that).
    anyway, after a few false starts, its in and looking ok. im thinking of bring it closer to the glass that its going to sit behind as i can more easily fit a custom bezel of some description.
    the old blue paint on top of the laminate had seen better days and was badly worn, so i tried a little acetone on it and off it come. the problem was the paint stopped the laminate fading underneath. after a couple of days it grew on me and i like the spacey grid type look left behind.
    there was 2 old coin mechs in the cab, but none of the 3 worked. after a bit of interchanging and made a complete one that works. coin door was sanded and given the dulux reco.
    the cabinet was broken apart in 2 places (not mentioned in ad tut tut) so after fixing it back up, it was time to decide how to best deal with large gouges down low on the front.
    1.6mm alloy chequerplate was used and i have matching chequerplate vinyl used in signwriting to do the sides that was lying around.
    i pulled the buttons and joysticks out (which were all very good) but the control panel itself was tragic. i took it to 2 sandblasters who wanted $40 to strip it as it was old powdercoat which goes like grease with the heat of the blast apparently. anyway, that wasnt in the budget so back home to a belt sander and a fine sander. i was thinking of using some carbon fibre vinyl i have here over it, but decided for $15 it can be powdercoated tomorrow and its not an issue i have to worry about again (and i can use the carbon fibre maybe as a surround on the glass)
    went to 2 places to find 16mm tee mould both neither had black (beige and cream seem very popular) so tomorrow i should find some i guess. Ive ordered tinted toughened glass for the top so maybe by the end of the week or the weekend it will be getting thrashed by the kids and i'll post some more pics. need to get a jamma loom, a marquee of some description and some speakers (the old favorites in use on this computer may get duty in it yet as they are too big for the cocktail)
    more to come, but thought it was time i posted something of worth
    Aussie : (Australian Slang) - a native or inhabitant of Australia
    Arcade : (Generic) - A type of game genre that is a fast-paced action game
    Forum : Noun (Latin/English) - A meeting or medium where ideas and views on a particular issue can be exchanged.
    I was watching that cab...
    Good pick-up and great thread. You will have the old girl going in no time...
    Keep the photo's coming...
      Cab looks great, well done
      BTW, where did you get the chequer plate from? I would like to do the same thing to my LAI upright cab.
      Matthew
        Those old Taito's are nice cabs.. Job well done..
          i got the chequerplate from AJ Stock at Hoden Hill (they do a lot of truck repairs so have offcuts of chequerplate at cheap prices) but any metal place will probably have it. i got mine in 1.6mm thick altho it is available in up to 6.4mm i think for those bulletproof installs ...
            Its hard to do stuff on a tight budget, but you have it looking pretty good now.
              yep, but tight budgets are ok when you got time hehe.
              i got the chequerplate vinyl cut to size today, dropped off the control panel to be powdercoated and i forgot the 8 bolts that hold the joysticks so i may see if i can get them done early in the morning or just fit some nice stainless button heads and maybe a carbon fibre overlay just for the hell of it
              but i cant find any tee mold (mould), knock in mold (mould) tee molding (moulding) in 16mm width with a 1.6mm spine in anything but beige, cream, white and brown. if i wanted to get it ordered online i would have done so earlier but the stuff is cheap (in the colors mentioned 1.65 a metre) and all i want is black (but the chrome would look nice). any leads to buy this in adelaide much appreciated as i want it for the weekend deadline for it to come inside and be played by the kids who nag daily ..
              anyway, the 1-2 player stainless steel panel in the middle of the console was dreadful. thinners and a good soak with goo off didnt work and it had these spots that wouldnt shift and i was almost to resigned to have to get it machine polished (95% of my tools are all still in storage till we find somewhere new to build a big shed and i have a polisher and linisher packed away). so i used one of the magic erasers ive used on the pinball playfields with much success and wow! almost like new and i didnt have to get out any polish altho it may need some bright shine to get rid of the last bits under the button edges but they wont be seen anyway. much more eco than other methods i guess too. the spots that werent coming out by any other method are gone. i may try some tooth paste to polish it gently. it is much better than the pic shows and that really surprised me.
              im thinking to order a pair of new 1 and 2 man player buttons with the one or 2 person image on them as they look neat and are right in your face on this machine between the controls. if the buttons werent all that good i would have liked to put in the illuminated ones *bling*
              one of the traders here may be able to get a jamma harness and a couple of buttons to overnight to me away tomorrow. i'll check it out later maybe.
                Did you find T-Mould?? I have 100m of 20mm that you can cut to 16mm. I found the holy grail of T-Mould suppliers. .88c per mtr in 100m roll of the best quality T-mould. I have got some off other people and it's been cheap platic crap. Only prob is white / black / grey. They don't have any other colors.
                That's the way Max Power is. Decisive. Uncompromising! And rude!
                  Nice work it looking good...
                  I need to build a low boy they look cool...
                  Movies are very educational. Example: I wouldn't never guess that a shoot in head can kill a zombie...
                    hey max, that may be the go, but paul i got the cab from reckons he may have some mold and evan a jamma loom, so i'll know in an hour or 2 if i'm a lucky boy as paul is only around the corner. i'll see if this pans out first but thats cheap huh?
                    in between getting the bolts to the powdercoaters, catching up with a mate and doing the op shop round with the family, i got one side of the cab filled (thanks to some old plastibond lying around), sanded and covered in the chequerplate vinyl. looks pretty good i think too. not as thick as the carbon fibre stuff which is what some guys use on their dashboards and other, but thin like normal signwriting vinyl. i got some rainbow sparkle stuff as well as holographic stuff i think i have to use up as well, but that stuff is real thick and is a buggar to cut on the plotter.
                    anyway, what was done before mr mom duty called. i get to pick up the CP tomorrow im sure and i think the glass will be ready by fridey i hope (i had put earlier i had it but i had only ordered it at the bargain price of $20 for 4mm toughened & tinted).
                    its still on for the weekend i reckon. lee, if you're reading this, come try your luck on it i reckon this weekend unless ive buggared the monitor by not getting it back together properly ...
                    is there any other way to get a marquee other than scabbing someones artwork or buying a ready done or do you go to a digital printing place and ask for a translucent print on perspex of supplied artwork done yourself?
                      Bazz
                      looking good mate , just shows you what can be done if you put your mind to it , was pretty sorry looking when it left my place , looking sweet now i dig that chequer plate look ,
                      Oh an i'm ok for the t mould still hunting for that jamma an i good to go with speakers i just have to test em
                      Pommie
                      should be home about 8 if you want to ring us
                        [QUOTE=Mr Pubstuff;303094]hey max, that may be the go, but paul i got the cab from reckons he may have some mold and evan a jamma loom, so i'll know in an hour or 2 if i'm a lucky boy as paul is only around the corner. i'll see if this pans out first but thats cheap huh?
                        That's the right price. Looking good. Love the green color.
                          happy days
                          i got a days work today at late notice so wasnt knocking that back, so off to pickup the control panel tomorrow. last night i disassembled all the buttons, cleaned and polished them and put them back together after the mandatory spring stretch and then cleaned up all microswitch tags with a wipe of the solder iron ready to put plugs on easily. that all done i know what im doing tomorrow night. hopefully the glass will be ready tomorrow, but even so its not looking great for a saturday session now on a finished machine, but sunday is still a good chance
                          still gotta do something about a marquee, waiting on a call back from paul about the jamma loom (ive already decided if i have to pull the loom out of the cocktail i will but id prefer not to of course). i still have to fill and sand the other side of the cab and decal tomorrow anyway and i'm mr mom all day so time will be low ..
                          ps: the green and the diamond plate (rather than chequerplate as ive been incorrectly calling it) is really growing on me more than i thought it would
                            Bazz
                            sorry mate can't find that jamma ok on t mould an speakers
                            ran late at work today should be home tomorrow around 7.30 after soccer try my phone then
                            Paul
                              beaut news thanks paul. unless some kind soul in adelaide has a jamma harness spare, i'll be pulling the one out of the cocktail cab tomorrow or saturday. i'll see you on friday night if you want to give me a tinkle or email when ya home?
