20" LAI resto/refit
  • 20" LAI resto/refit
    I picked up a couple of lowboys and pissed of that nasty Astro candy cab (spit) When we tried plugging this cab in it tripped the safety switch. Somebody had changed the plug and wired it wrong, the earth was on the active.
    Heres a quick thread on what I'd usually do. In this case the chassis was unsalvageable so I'll be putting in a brand new Jomac universal chassis.
    Just a pic of the cab, I've already taken the marquee out.
    Pic of the original Chassis..**** never seen one mounted horizontally like that..bodgy as all ****. The RGB wires are soldered directly to the pins.
    Inside the front. The distribution board, PSU and stepdown transformer are all mounted in a queerbo way.
    I'm going to take all this out and mount the distribution board and PSU at the bottom of the cab. This PSU doesn't work so im going to **** it off and put a Peter Chou in.
    I don't like the way the step down transformer is mounted (on top of the coin box) so I'm going to remove it. Usually I'd just hook the uni chassis to the step down but it doesn't really need to be. For those who don't know the Jomac universal chassis can run on 110 or 240 volts just fine.
    All the crap removed and the PSU and distribution board moved to where they should be.
    Removed the hornets nest and cleaned it up. Installed a new Fluro and starter.
    Here's the Universal Chassis in the box ready to go.
    On the left is the plug on the universal chassis on the right the plug I pulled off the stepdown tranformer to plug into the distribution box. I'll cut the top off the cord on the left and soldered it to the plug on the right. I wont need the ground wire in the middle so I cut it off. To make every thing nice and neat I use heat shrink tube over the wire once soldered.
    Universal Chassis installed. I love the remote adjustment pots on these things. Note that ive mounted them on the door and mounted the chassis so you can access the flyback (focus and brightness) and horizontal width adjustments from the front of the cab. I will never need to take the back off the cab again.
    Forgot to take a pic of the RGB wiring but its pretty easy, just match the colours and solder.
    Heres a pic of when i first turned it on. Make sure you always check your 5+ voltage to make sure its correct BEFORE plugging any PCB in.
    Close up
    There you go done and done and only took a few hours.
    The cab on the right has an old Kega chassis which I managed to repair. The thing needed a few caps and had to replace the suction cap on the anode because the bloody thing was like putty and half of it was still stuck to the tube.
    Power supply on the Kega needs new caps but it will do for now. The other problem with the cab is the fluro on it just blinks and wont come on. I put a new tube and starter in it so I'm assuming the ballast is ****ed?
    The LAI lowboys are the absolute BEST, I'll take these over a candy any day.
    Nice cabs AK, have to agree LAI are the best lowboys, mines not going anywhere
    "Beer, it does a belly good!"
      Agree - the LAI 20" cabs are nice, nice, nice...
        nice work mate a lowboy would be cool to have..
        Movies are very educational. Example: I wouldn't never guess that a shoot in head can kill a zombie...
          Yeah too right. they are made of Ply not MDF, the monitor is easier to rotate just unscrew from the top and turn and they are really well wired..
            Great write up Trav, well done!
            Regards,
            Johns-Arcade.
              Nice score trav. Why does that look like a lock bracket screwed to the distribution block The things ops do.
                Nice work Trav, great to see them going again instead of stuffed up the back of an Ops warehouse.
                  really nice, well done.
                    It would look much better at my place.
                    Very nice job.
                      Thanks guys.
                      I only put the thread up so it may help a newbie down the track in a basic cab refit.
                      I haven't really done anything out of the ordinary here
                        One good thing - at least the earth wiring was in there. Maybe not wired up properly, but in there.
                        Nice work mate, almost gets me geared up to look at my cabs and do something.
                        3 cabs so far, and all have monitor issues. Just over them all with knackered purity/geometry. Sydney must be full of yoke twiddlers...
                        Another tip for arcade newbies: buy a worker rather than a fixer-upper if you want to have some satisfaction.
                          Good to see kids enjoying NZ story.
                            nice trav
                            i liked my lowboys but i replaced them all with a slightly larger lai cab so its still sorta lowboy ish
                            theres a shortage of lowboys in the west people cant get enough of them atm
                              I think I've owned just about every Generic cab LAI built but have to say my personal favs are these 20" lowboys, 6 slot neo and the 20" 4 slot varient and last of all the mighty TMNT style cab.
