Rave Racer Restoration Project.
  • Rave Racer Restoration Project.
    A few moons ago i got hold of a Namco System 22 board from Gav. The board had been taken out of a gutted RR cab that was subsequently sacrificed to the arcade gods is a ritualistic cab burning.
    Small mamals who dwelt within the cab during its twilight years had caused some minor damage to the mainboard -which i am hoping to repair.
    After some screwing around with the board i found out that it is indeed a Rave Racer board. Only trouble is that nearly all of the wiring harness was missing and what was left was pretty crappy.
    Thus begins part 1 of my restoration process, building a wiring harness to test with. The System 22 cab is made of of 6 individual PCB's that come in at about 7-8KG in total. With the steel cage that houses them it is more like 15KG's. So pretty big boards.
    The four main boards are connected to each other using board interconnects. However, the EMI board has to be connected to the IO board via a series of cables, all of which connected through various IDC connectors.
    IO
    EMI
    PCB1
    PCB2
    So, at the moment i am going by schematics for Ridge Racer 2 in the hopes that i'll at least be able to get an image out of the board to assess whether our vermin friends have done ir-repairable damage to the board.
    RR2 Manual
    To Do...
    PART#1
    Build a harness from EMI PCB to IO
    Wire up a Jamma adapter to test the video output.
    Wire up a PC power supply to the mainboard and IO
    ...and eventually,
    Get all of the input peripherals including 6 speed geard box and set this all up in a cab.
    Okey Dokey...
    Seems that using IDC connectors is proving to be rather futile. First they are way too small to be soldering too and secondly they are way too weak for this application.
    Here is a pic of the original AMP type connector that was left on the board...
    AMP
    After a bit of ringing around I have found a Brisbane supplier of the parts. They got a $20 MOQ, so might need to buy more then i need. These amp connectors only come in 50pin configuration. The sales rep said to simply hack-saw it down to size.
    It amp Part #5-925367-0
    DATA SHEET
    Uses three different types of connectors
    #0-166310-2 High Pressure
    #0-141603-3 Standard
    #0-141603-4 Gold
    Time to do some shopping and throw out what i have done with the IDC connectors.
      Another update,
      I managed to make a "ghetto" harness using some spare IDC connectors and ribbon cables that i had. The AMP connectors are going to cost me a small fortune so i figured that i may as well see if it was worth continuing with.
      This first pic is off the harness that i made that goes inbetween the IO and the EMI board. I put quick disconnects on it to make trouble shooting easier (wish i hadnt though).
      I also made a "ghetto" power cable for the EMI board using a pre-existing wire harness, some clamps and an old ATX psu which i think i will use for this project anyway as the manual says that it requires 5V at 30 amps!!
      I bought the wrong friggin type of video lead so i wasnt able to test the video output, but upon powering up just the mainboard a whole bunch of LED's came to life. There are 8 LED's in 2 rows of 4 set up near the back of the CPU board. All four LED's on the farthest row from the EMI board lit up, but just a little whilst the closest row of LED's to EMI board just alternated between bulbs 2 and 4.
      I dont know what this means as there is now info on the net about this, but i assume it is complianing about something.
      I figured it had something to do with the fact that the IO board was not connected. So i hooked it up using my craptacular wiring abd ran power to it using equally craptacular methods and the LED's did the same thing. On the brightside though, the two LED's on the IO were lit up like xmas trees. (i presume this is good?)
      Anyway, hopefully George will be able to shed some light on this soon as he has got a fulyl functional System 22 board.
      Its off to Dick Smith's in the mornign to grab the right plug for my Amiga monitor!!
        Originally posted by Berty
        Another update,
        Hi Luke.
        I have the pcb here with me.
        Here are some pictures of the ace driver pcb and the i/o section.
        Pm me for more info.I then give you my phone number and we can sort out the problem you have with your Ridge Rider.
        Regards George.
        Doggistyler
          Made myself an RGB cable to go from the EMI board to the Amiga 1084 Monitor. Results aren't looking good atm
          When i fire the board up, i can hear a hi-pitched noise coming from the monitor and this garbage flickering all over the screen. If i unplug the AMP connector from the EMI board, the monitor stops making the noise. Im still getting the same LED activity as before. Im going to try and contact Namco but i doubt i will get any response.
            High pitch squeals and lines as such usually mean a sync problem.
              Found this post...
              From what i can tell, the board is not syncing cause it hasnt got enough juice.
                Correct me if im wrong but doesn't Rave/Ridge Racer use 24khz? if so its not going to work on the 1084s.
                  Nah, she's standard res
                    Breakthrough today!
                    Went round to trav's and hooked the baord up to his Nanao and got a picture! Colors were a bits screwed so i wired the RGB to an edge connector and bingo, got perfect video!
                    Pic1
                    Pic2
                    Pic3
                    Pics dont do it justice. Everything is there, nice and smooth with graphical glitches whatsoever. We ran the board for a good hour and bit and it worked perfectly the whole time.
                    I also re-wired the power supply today too and gave each ground and 5V line its own unique power line from the PSU. That managed to get rid of the flickering LED problem that i had before.
                    The second bank of LED's still continue to alternate blinking. It was mentioned in that news groups post that i put up earlier that it may be a result of low 5v. I can verify now that the error code means that the main board cannot find the IO board.
                    After the debacle with the video output, i wont be surprised if i find out that the IO problem is a result of my ghetto wiring. Nevertheless, George was kind enough to send up bits and pieces of his System 22 board so i could trouble shoot mine. So i should have a definitive answer on IO shortly.
                    Amongst other things, this pic shows the IO error message, plus some boobies too.
                    Big thanks to Trav and George so far for their help.
                    To do list...
                    Check the wiring to the IO
                    Get some sound happening
                    Build new harness
                      Yeah She wasnt going to go with the sync and green running through the sound ROFL.
                        George's IO and wiring harness arrived today. Tested my IO board out using George's harness and still got the IO error. The i tested out my board with his IO and harness but still the same result. Finally i used Georges EMI board, IO and wiring harness but still no luck.
                        This has got me thinking that maybe it needs to be hooked up to the whole shit show to work, buttons etc. Tommorow ill wire some micro switches up to my ghetto harness to get test mode functioning properly.
                          OKAY!!! BREAKTHROUGH!!!
                          Been talking to people all over Australia this morning on the phone. I came a across a rather helpful bloke in Melbourne through Zaxx. Name was George, and he was from "Leading Edge Electronics" in Melbourne also.
                          I described the fault to him and he knew the problem bang on and said it was a common fault. The IO error porblem is a result of a failed chip on the CPU board, not the IO board or EMI boards as i suspected.
                          He also mentioned that the game will run fine despite the failed chip, but you will not be able to start the game up.
                          The solution is too replace the CPU board which is actually quite easily done as all System 22 boards apart from Victory Lap are interchangeable.
                          He also mentioned that you can indeed swap games on System 22 board by changing the program and sound roms, and replacing the mask rom board on the CPU side with another game.
                          So to do list now...
                          Get another CPU board... DONE
                          Get yet another CPU board... DONE
                          Follow the traces back from the EMI baord through the CPU board to identify the faulty chip...
                            Nice persistence.
                              Well i got another tow system 22 board today, now i have Ace Driver, Ridge Racer 2 and Rave Racer, but no matter what combination of CPU/IO/EMI board i try i still get an IO error. One iteresting thing though is that when i fired up the ace driver board, i got another sort of IO error, even though the IO and CPU boards seem to be fine? This has me thinking that maybe the boards need to detect steering wheels etc to get a valid signal.
                              Im stumped. Im almost ready to give up on the whole thing.
