Cleaning old mechanical mechanisms in cash register's
  • Cleaning old mechanical mechanisms in cash register's
    Hey guys
    Spotted local garage sale had some old registers and counting machines so took a drive for a gander and came home with 2
    One i can take top off easily and other still working out
    Bit jammed up from years of storage with old grease, oil and gunk
    Safe to degrease or just soak away in wd40
    Main reason i got one as it looked cool and can see was once for a servo and other i grabbed while i was there incase got buyer regret at home (not first time it happened lol)
    Old lady downsizing her rural farm so said whole shed of stuff yet to be emptied soon so feeling hopeful for coin op as did see a phone stand repurposed as a plant stand
    Haha, good old buyer regret, we've all be there at some stage or another.
    Old registers are cool, got any pics?
      Only about 10km from home but nothing worse get back and go dam i should of got..
      Even then did forget to suss some dynamo looking transformers so hopefully next time
        Awesome, they'll clean up nice.
          I reckon you should be able to get some good info off Youtube etc. I'd treat it like an old mechanical pokie. No WD40
            Cheers rod. Will investigate as atm went in bit blind quickly but bailed once jammed up after getting one to actually work but not reset
              WD40 is only fine to free up the odd seized part that is hard to get to, by a quick squirt directly onto item your trying to free up, But dont go nuts with it and spray every part, Just the odd part your struggling with and then lubricate it correctly after it is freed up.
              Now dont use wd40 as the main Lubrication for the parts, it is not suitable for that sort of job, as Rod said treat it like a slot machine.
              Sewing Machine oil is good for lubing up parts during service,3 in 1 oil isnt to bad either, Dont use WD40 to service your machine.
              If the item is being used every day, often you would use grease on some parts, But obviously grease goes to shit and gunks up when its not used often so Oiling would be the best option if your using the item Occasionally, you just need to oil it more regularly if you do find your using it allot.
              If your going to use a degreaser Just be conservative with it, dont do what many people do, they spray these things with degreaser then finish the job off with WD40.
              take your time cleaning up the gunked parts, free up the parts then Lube correctly once cleaned.
                Cheers jason
                Will try sparingly and see if can get top off and inside
                National i can so will tinker that first i think
