Ipac config
  • Ipac config
    Once again its time for the potatoes piss lame noob question of the week.
    Finally got around to replacing my dodgy coin door ground wire on the w/end & got that working however when assigning the player 2 coin switch button in the Ultimarc config program it registers a "P" for pause, Iíve triple checked all the wires & it is definitely connected to the 2coin input.
    Iím just wondering whether Iíve confused the I-pac by making 2SW8 the pause button & now this has affected my 2coin input? Can someone with an Ipac test this by making 2sw1 pause & see if 2coin is affected?
    Chocolate covered potatoes on offer again.
    You can you check your Ipacs programming to see if coin2 has been reassigned. In a dos window type "copy con null" <enter> then press CTRL, ALT & P then type "L" to list your current config. You can make changes to your config from here as well.
