Fitting T moulding
  • Fitting T moulding
    Everythings in place now for me to complete my control panel,I'm hoping to have the finished article done over the weekend.
    I was wondering if anyone can advise me on fitting my T moulding.My groove is cut,and I have two right angled corners to get the moulding into.Whats the best way to get the moulding to hug the corner ? I was considering heating it just a bit to let it bend more,but I thought I would ask you guys first .
    pics
    In My "arcade":
    More to come!
      take a vee out of the prong at the bak of the tmould and it should go round easier
        Yeah, if its a tight corner a vee needs to be notched out of the barb. Don't use heat on sharp corners because it won't hold.
        Good luck!
          If you are using coloured T-molding then a little heat will help prevent white streaks when it is bent at sharp angles. Other than that cut a V shaped notch in the spine so that it doesn't fold on the coners.
            Thanks for the tips.I will go for the vee method for sure,also thinking of sitting it in boiling water before applying to make it more flexible.
            Will wood glue do for adhesive in the groove ?
              that or contact adhesive
                You shouldn't need any adhesive, its held in place by the ribs in the spine.
                  I really do need to do that "tutorial", don't I?
                    Yes , what a good idea Chris, do you mean like a video to watch?
                    Regards
                    Dez
                    DSB Electrical
                    DSB Electrical Facebook
                    VAPS
                    Vector Monitor Repro Parts
