help with torrentzip
  • help with torrentzip
    I'm trying to get the torrentzip program to run, but after unzipping the download file I can't find an exe. What am I missing? I use winrar to do all my unzipping.
    WANTED
    Another Holiday
    whats the file extension of what ever your trying to extract?
      I'm just trying to get the program to run, but I'm struggling. I've downloaded the files from here http://sourceforge.net/projects/trrntzip
      WANTED
      Another Holiday
        OK Followed you link, downloaded the Windows version - trrntzip_v02_win.zip
        Checked it out, it's one file .exe .. It can only be run from a command line. THe instructions that cames with it give you the steps to use it from the command line but they also mentioned there is a gui if that's mpre you liking.
        This is taken from the instructions..
        Forgot, you can actually drag the folder with roms in it over the exe, and it will do its magic!>
        TZ is very simple to use. It's a commandline app, so it has commandline
        parameters. This main parameter is the path/zip file that contains the roms
        you want to convert to TZ format. Remember, if a path is passed TZ supports
        sub-directories, so it will also scan these under the path you provide.
        Therefore, the calling convention is as follows :
        trrntzip <OPTIONS> <PATH/ZIP FILE>
        You don't have to use the commandline if you don't wish to. You can drag a
        folder to the executable within your GUI OS environment. This will
        automatically pass the path to TZ.
        Also available on the Sourceforge homepage is a Java based GUI for those that
        wish to use it. Please see the TorrentZip for Dummies document linked to at
        the start of this document for instructions on it's use.
          You downloaded the source code. Get the Windows binary instead.
            Yep you were on the money I downloaded the source code
            WANTED
            Another Holiday
              ok, scrub my post then, I lose
