Free windows system temp monitor
  • Free windows system temp monitor
    I have been using this for a while and like it. i use it in my lowboy that is use to run gameex etc on cos it can get a little warm inside the cab at times.
    dont know if others have seen it or not
    http://www.almico.com/speedfan.php
    If you need a tool that can change your computer's fan speeds, read the temperatures of your motherboard and your hard disk, read voltages and fan speeds and check the status of your hard disk using S.M.A.R.T. or SCSI attributes, then you came to the right place. SpeedFan is the software to go. It is fully configurable and you can create custom events to handle every situation in an automated way. SpeedFan works under Windows 9x, ME, NT, 2000, 2003, XP and Vista. SpeedFan works fine on Vista 64 bit too. The relevant driver is now signed with my digital certificate. And this all costs you absolutely nothing!
