Mamewah question
  • Mamewah question
    I have setup Mamewah as the frontend on my MAME PC and I am slowly working my way through the ROMset. I have noticed that some ROMs are not displaying in Mamewah even though I have not set any filters (e.g. clones, manufacturer etc). How does Mamewah determine which games to display in the list? I thought that all ROMs would be displayed but their status (working, not working etc) would be dependant on the version of MAME installed, but it seems that the game list is generated directly from MAME itself? I have MAME version 0.100 installed so does that mean that Mamewah won't show any ROMs created after v0.100?
    Matthew
    ** bump **
    Matthew
      Try this advice and link:
      http://www.mameworld.info/ubbthreads...=&fpart=1&vc=1
      Brad
        Originally posted by Brad View Post
        Thanks for posting the link, but it hasn't helped. The problem is not that MameWah doesn't show any roms but that it doesn't show ALL the roms, and I am trying to find out how the rom list is generated This may not be a Mamewah-specific issue, I have a feeling all front-ends behave in the same way.
        Matthew
          Okay I haven't updated mamewah since version 1.61 using Mame 0.92 but the later versions have issues with Mame's XML
          As for displaying roms, theres 2 ini options from memory on displaying clones etc. Change 1 of them and then regenerate the list to see what affect it has. I'm at work so cannot check my setup. I know that these 2 settings do affect which games are displayed.
          Brad
            Brad
            Just as an example, I have the 10yard.zip rom in my MAME roms directory. According to MAWS, the version of this rom is 0.108u5. Since I am running MAME v0.100, will I still be able to see this ROM in the MameWah game list or will it not be displayed because MAME does not know about it?
            Matthew
              The list is a static list. It's generated based on the version of mame your using and has nothing to do with Mamewah.
              So your list MUST match your Mame version for ROM NAMES at the very least.
              the reason is that when mamewah starts a mame game it passes the rom name in the command. In fact ALL frontends do.
              Now the list display does not need to match the rom name. Theres an option that displays the game name in the list rather than the rom name but when it passes the command it knows the actual rom name.
              brad
                brad
                Sorry for all the questions, but I'm trying to get this straight in my head. Let's say I have 100 roms in my MAME roms directory, of which 75 of those roms are v0.100 or earlier. Since MAME v0.100 does not know about the other 25 roms, will the game list in MameWah contain only 75 roms or 100 roms?
                Matthew
                  Correct well if I interpreted your question correctly. The list is generated by the version of mame that you ran the List Generation on.
                  So for example:
                  I have 100 roms from Mame version 0.100.
                  The version of Mame I generated the list against was Mame Version 100
                  I then add new roms from Mame 0.101 BUT I don't generate a new gamelist. Those new roms are NOT displayed in the list.
                  Just remembered the other value. You can set it to generate a list based on different methods. Rom folder or the other. Rom folder is of course based on the rom directory. Other can't remember but mame generated ot something.....
                  Brad
                    So for example:
                    Brad
                    We'll get there in the end
                    Can I somehow get the roms that are currently not displayed in the game list in MameWah to appear in the list, regardless of what MAME version I have installed? I have just found a rom (10yardj.zip) that is not being displayed in the list even though MAWS shows it as v0.027.
                    Matthew
                      Change the list generation method to Rom Folder and regenerate.
                      Brad
                        how did we go?
                          I changed the list_generation_method from rom_folder_vs_listxml to rom_folder and attempted to regenerate the list, but the roms are still not appearing. I have changed the setting back to rom_folder_vs_listxml but still face the same issue
                          Matthew
                            Change the list generation back and then change the ini value to show clones.
                            Brad
                              Brad
                              I can select an option within MameWah to show clones, but what is the setting in the ini file?
                              Matthew
