does anyone use an OMNISTIK prodigy
  • does anyone use an OMNISTIK prodigy
    Hello
    Anyone here use an Omnistik prodigy joystick ? (its the one that is 4 way 8 way switchable from the top ) if so what do you think of it ?
    Also where did you get it from ? they are obviously not available from any of the Australian sellers ?? unfortunately .....I would rather buy local if possible.
    thanks for any info
    I have a Mag-Stik Plus which is 4/8 swappale from from the top.
    http://www.ultimarc.com/controls.html
      Yeah i looked at that one..but thaught it might be a bit hard for the kids to change from 4-8 way,What do you think ?
      Also how does it feel as far as the throw goes ...is it a firm or sloppy feeling action.........Anyone ?
        I have 2 omnistick prodigy joysticks in my cab. i bought them from here http://groovygamegear.com/webstore/i...2b77f570a06ab1
        They are pretty good joysticks. I have never had a problem with them. Very easy to switch from 4 way/8 way. Only set back is that they take up a fair bit of room on the top of your control panel for the base of the joystcik where the switch is so probably not good if you have small control panel.
          The change from 4/8 is easy after you've done it once or twice, but without being shown you wouldn't know it's even possible.
          The feel is 'different' though. Because it is relying on a magnetic force to return the stick to centre it is very tactile.
            Thanks for the comments guys.
            seanj that could be a bit of a bummer with the size of the top plate cause my CP wont be very big..although looking at pictures of the Omni the plate dosn't seem to be too bad as far as size goes...i better find some measurements before i order anything.
            Just another thing ..does that little leaver ever get in the way???
            thanks
            john
              thanks
              john
              they take up approx 13cmx13cm give or take on the top of your control panel and no the little lever never gets in the way.
                Bloody hell ......130x130 that is a lot of space .
                thanks very much for the info ,it gives me something to work with ,its gona stuff the layout up that i was happy with but might still be able to make it work .......Just
                John
                  Hi Lexmark,
                  Is there a particular reason that you want/need switchable joysticks?
                  Chris
                    Originally posted by OzStick View Post
                    Hi Lexmark,
                    Chris
                    So you can play Pacman one minute, and Scramble the next.
                    Can't play PacMan (or Pengo for that matter) with an 8-way, can't play Scramble with a four way.
                      Hello Chris
                      DevoDave has hit the nail right on the head ....and you will know that he has when i tell you who i am ,John from King Island ....Remember me?? .......How ya going??
                      John
