i-pac2 dimensions help please
  • i-pac2 dimensions help please
    hello all
    I've searched but i cant find the dimensions of an i-pac 2 could someone please measure one up LxWxH and let me know .Sorry i cant reply to any replys till about 6.30 tonight
    thanks again
    john
    Just measured mine, I have the PS2 version (not USB)...
    53 x 98 x 16
    You'll probaby want more space than 53 wide as the wires come out sideways.
    Edit: and you'll want a few cms longer too for the PS2 cables!
      yep thats the size its small in size but is big itself if you know what i mean
        nope
          Originally posted by gemminislxau View Post
          nope
          lots of things to it like lots of inputs
            it might be small but it's had lots of inputs and you like to think it's big?
              i-pac2
              Thanks MrQuan for the measure...that should just fit where i want it to.The ps2 size WAS the one i was after
              Strange that the Ultimarc site hasn't even got the dimensions of this thing up...unless i didn't notice it .
              And thanks to the others for the "INPUTS"
                53 x 98 x 16
                Hmmmmm
                the USB and the PS2 ones are the same thing
                just the cable is a PS2toPS2 or a PS2to USB
                but remember to add 1 - 2 cm to the width for your wires to stick out and if you put it on PCB feet
                  sorry ...but may be a dumb ?? but what are "PCB FEET" ????
                  this MAME machine building is not as easy as it sounds.. i cut & assembled the entire cabinet in about 4.5 hours ...BUT its taken me 4 weeks to decide the CP lay out ( & still not sure if im happy with it ) & then there is still colour selection of trivial shite ...like buttons & joy stick knobs to think about ...im sure lots of you have been there & done that
                    http://www.gamedude.com.au/arcade/
                    In parts, pcb parts.
                    Look here, it mounts the Ipac to your cabinet..
                      What he said
                      good luck. I went with all white buttons that are lit from below with LEDs that can change colour ..... wanky i know but it solved button colour issues
                      see groovygamegear.com for pics of above idea
                        checked them out .....probably not for this cab. but will for sure keep in mind for one in the future......& thats not a bad site either ,thanks for the link
