TAD Cabal Trackball To Joystick Conversion
  • TAD Cabal Trackball To Joystick Conversion
    http://elgensrepairs.blogspot.dk/201...-joystick.html
    Good work, as usual.
    I have a Cabal PCB that has the Joystick Sub board, and can verify that the 2 enable pins of the 74LS244 are indeed connected to pin 15 of the daughterboard.
    My board also has the 2 extra hookup wires on the edge connector.
      Resurecting an old thread...
      Just performed the conversion and it went smoothly, works great.
      I plan on drawing up a proper schematic and clearing a few things up.
      SEGA love: | Nintendo love:
        Actually made a small batch of kits a while back with a proper PCB, ROMs, etc.
        https://m.facebook.com/story.php?sto...37999229703756
          Here's my contribution to the marvelous work of [MENTION=8767]Elgen[/MENTION]
          My intent is to simplify and better document the process for anyone wishing to perform this conversion.
          • You will need 4 x 27512 EPROMS and a suitable eraser / programmer
          • 1 x LS74244
          • Pin connector headers, male, 2.54mm pitch
          • ROMS 6, 7, 8, 9 on the CABAL PCB need to be removed and replaced with ROMS from the CABAL WORLD JOYSTICK ROMSET
            • CABAL ROM 6 = 10.6j
            • CABAL ROM 7 = 11.6h
            • CABAL ROM 8 = 12.7j
            • CABAL ROM 9 = 13.7h
          • The 2 socketed D4701AC's on the main CABAL PCB (they're near the Jamma connector) need to be removed and replaced with the JOYSTICK SUB PCB
          • For the roll feature, run a patch wire from Jamma pin 15 to Jamma pin 24 (TEST SWITCH TO P1B3) & Jamma pin R to Jamma pin b (SERVICE SWITCH TO P2B3)
          Below is the original PCB as designed by TAD:
          This is my recreation of it:
          You can download the Gerber files and have this PCB produced here: CABAL-JOY-SUB-GERBER.zip
          Schematic:
