World Rally Repair Log
  • World Rally Repair Log
    Symptom: Some colours wrong, for example car sprite colours and the hand at the start of a race. Also the test card colours in test mode
    Cure: Bad outputs on pins 12 and 13 of the 74LS298 at location G3
    Symptom: Some text a bit mangled
    Cure: Broken pin 7 on 27C4001 at location I11
    Symptom: Couldn?t adjust sound volume correctly
    Cure: A 5K volume pot had been used instead of the correct 4.7K
    Symptom: On power up, giving: RAM ERROR AT 00203FFE (sometimes the last three alphanumerics varied)
    Cure: Bad OKI MSM6295 at location C6
    Symptom: Sound a mess
    Symptom: Starting speech ?3 ? 2 ? 1 Go? kept repeating
    Cure: Pin 34 (A16) loose on OKI MSM6295 at location C6
    Symptom: 1 pixel high horizontal black line across the whole display on every other pixel line. Also colours a bit off.
    Cure: Bad output on pin 15 of the 74LS298 at location I3
    Some Legendary people here on the forum
    Well done!
    Regards
    Dez
    DSB Electrical
    DSB Electrical Facebook
    VAPS
    Vector Monitor Repro Parts
