Stephen Brown Posted January 25, 2020 Share Posted January 25, 2020 I have a cosmic monsters 2 that's acting up and need help. It stops and starts and freezes at times. I have video on utube under Stephen Brown. I have been told by an engineer that it could be the roms may need cleaning and reseated again. But still not working. Any ideas anyone? Olso looking 4 replacement roms and I.Cs as we and from programmer as well in order 2 make a backup copy of the game program. Link to comment Share on other sites More sharing options...
Administrators Arcade King Posted January 25, 2020 Administrators Share Posted January 25, 2020 Could be anything Stephen, bad rom, ram, faulty IC, bad sockets. If the games running then randomly freeze's you may have a bad ram or failing IC when it's heating up. Can a freeze spray can help determine which one. My suggestion is to read the stickies in the Arcade Technical and Repair Questions channel and do a search in the repair logs for symptoms like yours, you're going to need some basic diagnostics tools also. Link to comment Share on other sites More sharing options...
