Kagi Chassis Turns On Then Off Stright Away
  • Kagi Chassis Turns On Then Off Stright Away
    Fault:
    Turn chassis on ands turns off stright away small high pitch whine
    Repairs:
    This chassis has had caps replaced not long ago so i didnt think this was a cap issue. Did a few checks HOT was ok and flyback was fine so that wasnt the problem. B+ voltage was ok from ps pcb.
    What i did find which i have seen before on another chassis was the control pots that adjust your H posi H Hold ect when touched the tracks would gentley move. I found that when i went to clean each solder connection the solder track on each pot the solder pad just flaked away. I cleaned each pot solder pads and repaired the broken ones.
    Powered up chassis and came up with a nice clean screen
    any chance you can send me some pics of the kagi chassis wired up as i have the same chassis and need to hook it up. I gutted my machine for restoration now its time to start wiring things back up I forgot to take phots to remember where everything went. Im sure i have everything right since the plugs usally only fit one spot but I really need to know which of the two are the HOT and Neutral pins on the power supply board.
