Taito L-Shaped PCB Repair Log (Sound PCB) Graphics Glitch
    I had a faulty sound PCB which after socketing and replacing the LM3900's and the 7417's, I got all the sounds working but the sound PCB also had a graphics glitch.
    There were lines through the invaders, their shape was wrong and they would charge straight to the bottom of the screen after a couple of changes of direction and the game would reset.
    After probing the outputs of the 74151s I found IC [3] had it's output stuck low on pin 5.
    After changing it the was some improvement, the invaders were no longer blocky/wrong shape.
    Looking at the inputs of this bank of chips I found DS8 was stuck low, the input was coming from the 74175 at IC [12], pin 2.
    After replacing it the graphics glitch is now gone and the game plays normally.
    [MENTION=6328]lentildude[/MENTION]
