Gamebox 2011 G2S3PH T091028A Manual or other info
Discuss multi boards here IE:1000 in 1, 48 in 1 etc
    Hi Everyone,
    My boss got a Gamebox G2S3PH (manufacture date 2011, JAMMA PCB part T091028A) secondhand from somewhere a couple of years ago and has recently been having some issues with it. The unit did not come with any manuals apart from a list of games.
    I've managed to get the system working (removed JAMMA board, removed RAM and cleaned, reassembled), but my next concern is the HDD. Can the HDD in these units be easily backed up and is there a built in backup utility?
    Really, I'm looking for any manuals and advice that people may have, mostly around performing the backup, but also any/all features of this system.
    Having never dealt with JAMMA or Gameboxes before, I know very little about it, but from what I've deduced, it's a standard PC with a JAMMA interface card (which appears to emulate a PS2 keyboard and interfaces with the LPT port for additional signals), is there much more to it?
    Anyway, any info would be greatly appreciated
    Thanks.
    Originally posted by Macka View Post
    Hi Everyone,
    Thanks.
    you can definitely back the HDD up, use an imaging program (for eg acronis self-image) and put the hdd in a usb caddy or just connect it to your pc via a spare IDE slot. (assuming it's IDE) you need to take an image of the whole disk as these images include multiple partitions, some that windows can't access normally.
    I started a thread on here about 6 years ago to do with these gamebox machines, i built a new customised image for the system and distributed it on AA.
    i don't use the system any more but this thread has a lot of information in it though it is pretty huge, 16 pages. Off hand, I don't know of a manual's location, but someone else might.
    Customised HDD image for xxxx-1 systems inc Laserdisc Games - anyone want one ? - Aussie Arcade
      Thanks Jed.
      I've successfully backed up the HDD to a 120GB SSD using the HDD copy tool here: HDDGURU: HDD Raw Copy Tool
      Still wouldn't mind a manual if anyone has one?
      I didn't realise that the image in that thread was compatible with those boxes, I have looked at some of it previously, might have to read a bit more.
        Thanks Jed.
        just did a quick search and found one, here you go
        Games Family xxxx-in-1 Arcade Classics Multi-game Operating Manual - AceAmusements.us
          I did find that manual, but the board is different. It could be that SW1 & SW2 in this manual are just 1 big switch on the board.
            I have this same board with issues. Mine only plays certain games. Did you experience this? Also did you find the right manual?
              you can definitely back the HDD up, use an imaging program (for eg acronis self-image) and put the hdd in a usb caddy or just connect it to your pc via a spare IDE slot. (assuming it's IDE Mega Moolah kostenlos online spielen 🔥JETZT🔥auf Mega-Moolah-Slot.com]mega moolah[/url]
