Arcade help - xxxx-in-1 button setup
  • Arcade help - xxxx-in-1 button setup
    Hey guys
    I just got my xxxx-in-1 board and need some help setting it as well as my buttons up with it, as i have pretty much nfi about it all. I was wondering if anyone in the canberra region could lend a hand?
    cheers
    This shouldn't be in the wanted section.
      hey, no worries, where can i put it bud?
        moved.. thanks for the heads up, and title changed to add a bit more info.
          thanks gents for that, its basically setting up the board as well as connecting the buttons. hope someones able to.
          cheers
            Gday,
            I've never set one of these up - my 60-in-1 has just arrived and I'm still building my cabinet.
            Having said that, do you have a JAMMA harness? What cab is it going in? What are you using as a Power Supply?
            Cheers!
            Maz
              ive got my cab, I have it all set up from before, running snow bros on jamma harness, preeeeeeeeeetty sure they have given me a kick harness for extra buttons, have all the buttons and microswitches set up, just need to connect them to the harness, as well as make sure im not ****ing up a expensive piece of equipment
              and they provide a power supply as well as the standard one which was in the cab to begin with
                I'd be doing the following:
                • Check you have the correct harness
                • Connect the additional buttons to the harness
                • If unsure about wiring, grab a multimeter to test with
                • plug in harness
                • turn it on and test
                Provided your not running any power through the harness, from what I understand, you cant really go wrong.
                Is there something your specifically concerned about?
                Maz
                  im just concerned really about my lack of knowledge, and it talks briefly about ****ing it up and damaging it ra ra ra and there goes my board. I just dont know enough about it as im pretty sure i need to solder the 4th button now onto the jamma harness as well as connect up the last 2 buttons. its just a lot of know how which i dont have regarding arcade machines. My goal/hope is to have it all done by next week, so hoping someone close will be able to pipe up and lend me a hand
                    Howdy,
                    Assuming this is the manual for your xxxx-in-1, it should have come with a "kick" harness for the additional buttons.
                    You'll need this for buttons 5 and 6. Wire the buttons to the corresponding pins on the kick harness. These buttons should share the ground from the kick harness.
                    Button 4 will need to be wired into the JAMMA harness - the manual will show the pinout to be used for this.
                    The button wiring - You'll want to connect the COM from the button to the ground of the harness. The other wire should be connected to N.O. (Normally Open).
                    As I said earlier - I havent reached this stage with my cab, so I'm going to throw this out to those more knowledgable...
                    All the best
                    Maz
                      I am not sure but wouldnt there be a slight difference between different multi game systems, eg The RED BOX vs the 1066 etc.
                      I have the "RED BOX" from Game Dude and that was pretty easy to hook up.
                      Wouldnt have a clue about the others.
