Would it be possible modify XXXX-in-1 run from memorycard?
  • Would it be possible modify XXXX-in-1 run from memorycard?
    It it possible modify XXXX-in-1 run from memorycard? Just copy HD to big memorycard and use CF adapter or something..
    Or use SSD disc..
    I wouldnt like to use HD based system, maybe I just worry HD fail one day..
    I don't know if it's possible to run it from a solid state drive but I would suggest backing up the HDD with Norton Ghost because that chances are, it probably will fail eventually.
    There is a tutorial here: http://www.xxxx-in-1.com/modules.php...iewtopic&t=236
