the multiboard red light of death?
  • the multiboard red light of death?
    got a phone call few weeks ago from a mate who's 48 board had died
    took out another tested machine all good. bought his home tested on 3 machines no go. tested various PS and monitors to be extra safe. it had a red led flashing on the bottom corner
    tonite though heck ill test that mini PS and see if it powers the board and plugged it in and no red light
    take it down the shed and bang board is now running?
    for several days i tested on and off and no go. now after just sitting around the board works
    i almost frisbee'd it out the door
    "o" the joy of arcade repairs and maintenance.
      yeah. i was glad i only just got some new ones in when my mate rung
      fired up several times and all good
        I had this problem once when the JAMMA Socket was worn and too wide (By about 1mm)
        The PCB wasn't seated right
        Maybe same??
        Regards
        Dez
        DSB Electrical
        DSB Electrical Facebook
        VAPS
        Vector Monitor Repro Parts
          Shannon, try swapping over the eprom with another 48 in 1 board.,
          I have had one with this same issue that had a faulty eprom. Replacing it fixed it.
            cheers guys
            both were new harness's. its still going fine ill look into the eeprom as i dont have a burner as yet
              If it is going ok, then just leave it, first rule in the repair bible.
                ill kill this thing
                died 5 mins before a buyer can to look at the cab and board
                thank goodness for plan B
