power supply question
  • power supply question
    got a PS here off a usb to ide adaptor
    wondering as it goes straight into a HD will it be ok for a multiboard?
    its tiny size makes it a good choice for a bartop or similar
    cant see why it wouldnt,give it a try and see how hot it gets
      it gets hot usually but have had it once plugged in for several days as i forgot to unplug it
      thought for home use machines only get turned on around 1hrish at a time
        It should be marked with the rated output voltage and current. You'll also need to check the power requirements of the multi board.
          12v 2a
          5v 2a
          ground
          cracked it open and will test with it open to keep it cool
            As long as the voltages are correct, and the current requirements of the board are less than the capability of the power supply, that should be fine.
              2Amps from the 5 volt supply sounds a bit on the light side to me, but it does depend on the game.
                48in1
                  I pulled a desktop computer apart and found a baby power supply inside. It is 95watt. I thought it might be good for running a 48 in 1 inside a cocktail. It is smaller than a normal pc power supply and it outputs +5v @ 10amps. Should be more than enough. What is the current draw for a 48?
                    If a 2amp is working ok on NARF then your ten amp is more than enough to do the job, that would also mean that the 12v is around 2 amps allowing for the others?
                    what else is the psu putting out 3.3v 5v -5v 12volt?
                    the 95 watt is the total of the combine output.
                    The PSU should tell what each voltage, current drawing capacity is- remember watts = vxI (voltage x current)
                      hey guys i thought id update
                      the little unit didnt have enough guts to boot up a board so it went frisbee in the shit bin
                        Thought that would be the case, good to be updated.
