60 in 1 board prob
  • 60 in 1 board prob
    new to this arcade rework. i have a 60 in 1 board. that dies after about an hour of play. i get a no signel box on the moniter. checked the power supply 12+ 5.1+ 5- checked the dip switchs checked the vga cable. looking for help. thanks
    Ideally, you'd be best off trying another board in that cab or trying that board in another cab to narrow down the fault.
    BTW, welcome to AA! If you fill in the location field of your profile, maybe someone close by will be able to assist?
      Could be a heat problem install a cheap 12v fan that forces a good flow of air over the boards?
      otherwise sounds like you have check all the regular stuff, just make sure that all the plugs and sockets are tightly in place and the pins are not corroded, with heat and vibration they can work themselves loose
