Saving high scores in a 48-in-1
  • Saving high scores in a 48-in-1
    Hi guys,
    I've got my lowboy converted & configured almost perfectly for the 48-in-1 board, however I can't work out the 'save highscores'.
    I looked in the manuals and it says to flick 'dip switch 3' to 'on', to enable high score saving... however when I power off, and power back on, the highscores are lost.
    Am I missing something? Does 'enable highscore save' only mean that it saves only until the power is turned off or something stupid? Is there a known problem with 'older' versions of the 48-in-1 or something?
    I like the 48-in-1 board for its simplicity but its really going to defeat the purpose if it doesn't save my high score (how else do I get bragging rights with the kids?!).
    Btw the game I'm using to test this is Juno First. Can someone with a 48-in-1 confirm whether or not after a power off/power on, their Juno First highscore is in-tact?
    My Projects
    What they do is keep the "Highest Score". On games with Top 5 or top 10 scores etc. It will remember only the highest score and forget #2 down. Also entering your initials is pointless as it forgets them as well.
      Yeah on most games it bloody saves your name the when you start up the score is there but it changes name to Lee.
      That's the way Max Power is. Decisive. Uncompromising! And rude!
        Bugger, well at least I know what to expect, thanks for the info guys.
        My Projects
          Yup. Also on mine Pac Man Plus doesn't save high score at all. Not that i play it much, as it's pretty intense straight off the bat. Good game to play if you only have 2 minutes to spare
            Mine loses HS as well
            48in one LAI coctail
            This really pisses me off
            Hope someone can come up with a solution
            I believe PCB will require a backup battery
            Pinball, Its an Addiction
              I've got an answer for you:
              Change your mains to turn the tube and marquee off, and always leave power to the PCB. Kind of costly, but will keep your highscores going.
              My Projects
                My highscores save, but the initials dont which sux.
