  • 0
MORE INFO on my game box
metz
Question
chipsets are
NORTH is VIA 8601T
SOUTH is VIA 82C686B
Files on the HDD are:
adv084.exe 6331 KB
advmame.exe 6183 KB
autoexec.bat 1 KB
cx423x 4 KB
endt.lst 6 KB
es1883 4 KB
game.com 7 KB
viaudio 4 KB
can anybody help me?
thanks
17 answers to this question
  • 0
Dude we are still no wiser.
Maybe coolspot can help you.
What kind is it, what colour is it, what does it look like?
Where did you buy it?
How many games are supposed to be on it?
Is it JAMMA?
What did you do to it to make it stop working?
So far I know you have a game box that you've pulled the hard drive out of and it has some sort of DOS on it with the above files.
  • 0
I can't do a link to the original thread
maybe a mod could help me
its blue
its jamma
and its 200-in-1
hey guys I just want to start of by telling you this is a GREAT forum!!
I have tried to find the answer by reading and sending a few PM's out
a BIG THANKS to everyone that answered :sm1:
GAMEDUDE suggested I start a new thread because he didn't have what I needed and would help if anybody had it (THANKS AGAIN )
I took the HDD out and put it in another puter and the files were there
but strangely they were duplicated (one file had them all in itself and if you click the same folder inside itself it opened again and again about 50 times)some of the folders were empty:unsure
well i tried repairing the drive within windows and all the duplicates were gone and the empty folders had something in them (at this point I thought I fixed it :cry)
I tried setting the dip switches different but no luck :x
here are some pictures
http://i2.photobucket.com/albums/y25/metzjames/DSCF1506.jpg
http://i2.photobucket.com/albums/y25/metzjames/DSCF1504.jpg
http://i2.photobucket.com/albums/y25/metzjames/DSCF1499.jpg
http://i2.photobucket.com/albums/y25/metzjames/DSCF1494.jpg
also there is a tag that reads
"model 200 in1-3
s/n 02007-063152700
input ac 220v-240 50/60 Hz 1.4A"
I just want to say THANKS in advance
metz
this is from the thread here
http://www.aussiearcade.com/showthread.php?t=13233
  • 0
BIG GEORGE now what do you know?:unsure
you had somethang to say before:evil
could anybody point me in the right way?
sell me the correct HDD and tell me the files I need?
otherwise I'm selling it even tho its a little puter
THANKS in Advance!!
and have a Merry Christmas
  • 0
  • 0
chipsets are
NORTH is VIA 8601T
adv084.exe 6331 KB
advmame.exe 6183 KB
autoexec.bat 1 KB
cx423x 4 KB
endt.lst 6 KB
es1883 4 KB
game.com 7 KB
viaudio 4 KB
thanks
Hi metz,
I am a computer tech and while not familiar with your setup, it looks as though it is meant to boot a version of DOS or PC DOS or something. If the files you listed are the only files on the drive then you are missing a few. Make sure you check for hidden and system files. Can you post the contents of the autoexec.bat file?
It would be easiest if you contact the manufaturer and tell them your HDD failed, what do I do know? Did it come with any disks at all?
Stuart
  • 0
nothing in the file you asked
I brought it 2nd hand so no disc
I will have to call them when the time is right over there
But will they speak english?
thanks for your time
does anybody have an Image even close to this that I could try?
thanks agin
  • 0
The autoexec listed in your first post has the size as 1KB - ie, there is something in it. If you open it with something like notepad and it is empty, then you have surley suffered disk corruption. As I said before, you are missing a few files.
I am not familiar with advmame but it may be possible to get this machine working by getting a copy of advmame, setup a new hard drive with a dos boot - try boot.disk.com for ideas,
format x: /s
may help you. You would need to load drivers for the sound through the config.sys file, which you are missing. You would then need to find out if there are any command line switches needed to run your Jamma board.
My best suggestion, if you can't get joy from the manufacturer, or find someone with the same setup, let someone who has experience with dos based setups loose on it.
Other than that, surely someone knows how to make mame work with the Jamma boards.
Good luck.
P.S. from your photos, the hard drive looks like a Quantum Fireball - yuck. If you get it up and runninf, clone it to CD.
