Help XXXX in 1 ZAP!
  • Help XXXX in 1 ZAP!
    Turn it off before tinkering?
        Originally posted by BuRNZ View Post
        Of course I turned it off before tinkering but I think these monitors hold a charge?
        Just reading up on it now.
        http://www.andysarcade.net/personal/...ischarging.txt
        Yeah, they sure do - looks like you have found something useful there. I forgot to use the smiley last time.
          the charge shouldnt affect you unless you were trying to remove the chassis from the tube as far as i know. Does the monitor still power up?
            Your PCB requires 2 power supplys.
            The ATX will fire the board and show a pic on the screen. The Arcade PSU allows your joys and buttons to work. If they aren't working that the first place I would check.
            And yeah, be careful mate. I haven't had a shock for a couple of years now (touch wood).
            Just watch where your hands are going. Nobody wants you to get hurt.
              2 shocks this year, 1 from a TV that I pulled-apart, and one from a pinball as I was leaning in to reach a stray screw.
              TV one hurt alot more.
                Generally if you brush it with your hand and your other hand is near or touching metal *BANG* your gunna feel it...........proffessionals, i have heard always force themselves to keep on hand in thier pocket at all times!
                Eg, only use one hand at a time (if you can), trust me it works, it's a good zap but wont really hurt you unless you have a weak heart, or if it scares you then you rip your hand out slicing it on sharp metal as you do!
                So remember keep a hand in your pockey, and try not to touch the flyback plug on the tube, or if you are really worried discharge it, but i think it's overkill if you aren't doing anything to the tube/chassis.
                _______________________________________
                Nathan.
                    Sorry to raise the dead but better than starting another thread.
                    My cocktail cab powers up game menu on the screen. It even makes the coin sound when I insert a coin. But the controls still don't work.
                    I've gone over this mess of wires as best I can and found this wire has come loose.
                    [ATTACH]8993[/ATTACH]
                    Could this be why my controls no longer work?
                    It looks like a ground wire for something - No doubt it needs to be re-connected!
