vert games on horiz monitor ?
  • vert games on horiz monitor ?
    do any of these xxxx in 1 boards allow you to play verts on horiz monitors and vice versa ? like mame
    sorry if this has been asked before, couldnt find it
    Yeah they all do but you have to physically turn the screen to the other position and mount it that way, i think, i might be wrong?
    anybody?
    _______________________________________
    Nathan.
      thanks for your reply neo
      i mean without turning the monitor, like mame on the pc, plays vert games with black on the sides of the screen
        The XXXX in ones are suppose to be Horizontal only, but with all the hacking with these I can't see with a bit of changing some ini files it can be done in vertical mode..
        But back to your question:
        Yes!... Mine isn't the latest, but I;ve added a lot of vertical games in, you have to change the ini file to give a better aspect ratio, otherwise it fills the whole screen...
        I;ve got a sticky on here about adding games and changing ini files...
        Not sure but I think the latest version they've sorted vertical games display not to be stretched, but not sure..
          according to this games list, the 1069 in 1 horiz board has bombjack, 1942 and heaps of vert games, hopefully they have black edges
          http://www.jammaboards.com/arcade_ma...amily_List.pdf
          stretching the game is a bit ghetto
            this forum has a few members here and visa versa
            http://www.xxxx-in-1.com/modules.php?name=Forums
            this might help you answer the serious questions
              thanks narf
              nice 1, i'll check it out
                There is actually a variety of 1066-in-1 units that's made to play games in both upright and vertical (i.e. cocktail) modes.
                I bought my 1066-in-1 built in with a cocktail table, which is just like this one currently listed on ebay:
                http://cgi.ebay.com.au/ws/eBayISAPI....m=360079787471
                These units have 2 menus (i.e. upright and vertical) which you can flick between at the push of a button. They're pretty awesome coz you get the best of both worlds
                For further threads on these badboys, check out these links..
                http://www.xxxx-in-1.com/modules.php...ewtopic&p=2148
                http://www.aussiearcade.com/showthread.php?t=16729
                  interesting read!
