Screen Shot of 48-in-1 test pattern?
  • Screen Shot of 48-in-1 test pattern?
    Guys,
    Trying to sort out a colour problem in my cab - was wondering if anyone could get me a photo of the test pattern of a 48-in-one, or at a minimum tell me the order of colours for the top row of squares?
    Much appreciated!
    i cant remember but i recently tuned in my colours
    if it helps i turned them all down on the chassis to low and one by one turned them up till the squares went blurry and tuned them back till perfect squares
    did it for rgb and colours are smick
      Thanks mate, 1st thing I want to check is that the RGB wires are the right way round.
      Pulled miles of shitty extended wiring outta this cab... so anything is possible.
      Biggest problem is that the RGB adjust pots are facing the back of the cab, and they are close to the back too - so fiddling with them seems a bloody dangerous operation!
      Also have some screen warping - will need to spend some serious time seeing if I'm just better off with a new universal chassis... The current one is a sanyo, but thats all I know about it...
      That and I can see the convergence rings have been twiddled
        is the cab going to be dedicated 48in1?. if so a cheap option is to just use a crt pc monitor
        i find 2 people are best to work on monitors unless you have really long arms
          from one of my earlier posts
            Awesome mate, just what I was after.
            Now to get home and figure it out!
            Pretty sure one of my squares is grey
            Oh well, it's all fun and learning...
