19 in one?
  • 19 in one?
    a did a search and didnt really find much about this board
    (sometimes called the williams board I think)
    is it any good and why in the heck is it so much money?
    does anybody know where I could get one?
    thanks in advance
    Jammaboards have the 19 in 1
    http://www.jammaboards.com/store/19-.../prod_229.html
    but if your after a programmable one I personally think this one is the Ducks nuts
    http://www.arcadeshop.com/multi-pcb/multi-pcb.htm
    but like you say very expensive
      I would really only want that for the mario titles, hopefully they get cheaper
        thanks for the info guys!!
        I like the 19 in one for the Wiliams games my self (I LOVE robotron!!!)
        and I have a XX in 1 (blue box) that I need to send a HDD out
        but I really like the idea of a couple of cabs instead of just a MAME box
          A few games have issues.
          If you move the joystick left or right in Defender, it reverses and thrusts in the direction you hold the stick. You need a toggle to disable the left and right to play it properly. Also there are button conflicts with 2 player Joust as well. The button mapping hasn't been thought out at all. You need to run extra wires for player ones flap button and this inteferes with Defenders reverse button. Another toggle is needed.
          Oh and also, If you have it set to 'upright 2 joysticks' in the menu, you can't play doubles because the machine expects you to have a full extra set of controls. If you have it set to 'upright 1 joystick', simultaneous games like Joust, Bubbles etc are 1 player only.
            are the programmable ones pretty spot on gibo? I want to turn my defender into a Williams multi and looking at all my options.
              AK. That board is the bomb. Forget the Chinese ones.
              everything is spot on.
                Mate I think you and I have had this discussion before,I like the programmable one myself but if you have a working Robotron or Joust board,not sure if you can use a Defender there is another option using the addon rom/daughter board which I think was the original multi williams setup and its cheaper too and after reading a lot of your post Id reckon using original hardware is your thing
                http://multigame.com/williams.html
                I have heard the same things that Spacies mentioned about the 19 in 1 but to overcome this people have just disabled some games
                  i remember the perth meet one of those williams boards was running. small little suckers.
                  looked good the arguement about a enemy not dying in moonpatrol was classic to watch
                    problem is mate clay doesnt make those multigames no more
                      can they be copied perhaps?
                        Bummer ,didnt know that,not many options left then
                          With the programmable multi boards, could I install variants like Luner Rescue and Space Laser, Space War Part 3 - SI variants and the like?? and what about Space Chaser?? or is this board pretty well locked to the games list as shown??
                          Forgive me if its a stupid question, if it can, I would get one in a shot!!
                          CliffyT
                            CliffyT
                            As far as I know its only the games on the list which are supported but they seem to get updated fairly often with new ones
                              I was thinking of getting this 19 in 1 from Ebay. Mostly because of Defender and Stargate. I have 48 in 1 and some games have bad sound problems. How is this 19 in 1 board?
