Hey all,
As per title, after some advice.
Turned on my MK cabinet today and I've got vertical collapse, which from searching the forum I understand is chassis related.
However, the monitor is a 25" 59cm Orion which Jomac has posted on these forums is a POS, which was recalled shortly after it was originally produced.
So, should I send the chassis to be repaired or try to get a old of a 59cm tube and then get a universal chassis from Jomac?
I'm thinking the second one is a better option if I can find a tube.
