OK! So thanks to serviceit, i finally have access to a transformer that has the proper specs to run the monitor. Ok, so here is whats happening. The screen is a blue when i start it up, even with the degause coil plugged into the monitor. Adjusting the pots doesnt seem to change the colour but one problem at a time. The main problem is that when I start up the monitor with a game board attached that has power going to it(used that home made supergun tut to hook it up to pc power) the thing flips the house saftey. Now, on the chassis the 2A fuse blows when this happens.
So, what are peoples ideas on how to resolve this issue. I might just have to get an arcade power supply but i would like to avoid that if possible. Mainly because if i do that i would need to get a new jamma harness aswell with wiring because the wiring on this one is all soldered to the board and doesnt look very good at all.
Question
opm881
14 answers to this question
