I got the colour issues ...
  • I got the colour issues ...
    OK ... so I'm thinking a degauss might help the situation ... but I'll see what you all think before I go jumping the gun.
    I believe what I have is a Kortec 25" based on posting certain numbers I discoverd into Google and seeing what came up. I've just got it all up and running this weekend and all is going well, except the colours are a little messed up. Things are reasonably clear, however on sides there is some serious red tinting going on.
    I can post pics if that will help, but I'm just wondering if even based on that description anyone can give me some advice?
    Thanks ;-)
    look for a small ajustement pot on the neck board (little board on the end of the tube) marked red and try adjeusting the red cut off.
    best to put a mirror infront of the cabinet so you can see while adjusting.
      I think red tinting on the sides is more likely to be magnetic related. Go with the degausser.
        removed message
          should have read you first post more closely .
          You need to degausse you monitor like Dave said
            something similar happened to me, when i turned it 90 degrees it was all good, looked to be magnetic.
