Distorted screen and smoke
  • Distorted screen and smoke
    I have a Gottlieb low boy ???
    Moved it a couple of days ago . Turned it on today and see pic below , the screen is all haywire. Then the dreaded electrical smell and smoke coming from the area in pic 2. It has a 60in1 board and I know jack s__t about these things. Pinball yes arcade no. Any ideas ?
    Sent from my SM-G950F using Tapatalk
    Good chance the yoke has fried.
    What chassis is it?
      Looks like the brown glue strikes again. It corrodes the copper windings. If u take the yoke off you'll probably see.
        Ok whats the yoke ?
          The part in your photo with the yellow/blue etc wires attached to it on the neck of the tube.
            Ok will check it out tomorrow. If its cooked what then ?
              What chassis is it?
              Thanks for your reply John , as I said I know nothing about this so what is the chassis
                The circuit board thats connected to the monitor (one on end od tube is a neckboard)
                Lcd is a option with a 60in1 as replacement too
