WPC No Sound
hotty
Was putting some LEDs in a Getaway found there was short in one LED which caused the fuse to pop only to find which LED was the culprit by using a re-settable breaker I made. But after some time I noticed whenever I switched the machine on there was no bong or any sound. Well here we go checked fuses, checked board checked everything I could think of, I did fix it but does anyone want to have a go at what it was? I will post the result.
8 answers to this question
  • Super Moderator
I'm embarrassed to admit that I got caught once in that I had no sound to find out later that the volume was turned all the way down..
Check you volume.! ;)
Bingo @robm the sub woofer/cabinet speaker connector was a bit dodgy but not removed as you know Rob stupid series wiring for the WPC speaker set up. I looked at the wiring so many times until I decided to touch the lugs after all other tests were exhausted. Edited by hotty
