• Enraged
  • Embarrased
  • Drunk
  • Down
  • Depressed
  • Crying
  • Crazy
  • Cool
  • Cocky
  • Bemused
  • Awesome
  • Annoyed
  • Angry
  • Amused
  • Friendly
  • Geeky
  • Godly
  • Happy
  • Hateful
  • Hungry
  • Innocent
  • Meh
  • Piratey
  • Poorly
  • Sad
  • Secret
  • Shy
  • Sneaky
  • Tired
  • Wtf
  • Thanks Thanks:  0
    Page 1 of 2 12 LastLast
    Results 1 to 10 of 18
    Thread: Taito Space Invaders. Rolling screen.
      aaablettt's Avatar
      aaablettt is offline
      is Happy
      Happy
      Apr 2013
      1,023
      15 Post(s)
      226 Post(s)
      Hi Guys,
      I have a rolling screen no matter what monitor I use. Any ideas?
      crackedMagnet's Avatar
      crackedMagnet is offline
      This user has no status.
      Jul 2017
      Wellington
      23
      10 Post(s)
      New Zealand
      As i understand it rolling can be a v-sync problem. Does the output to the monitor have seperate h-sync and v-sync or a composite sync? Generally you can tell by the number of wires, 5 wires for composite sync (RGB, GND, Sync), 6 wires for seperate sync (RGB, GND, v-sync, h-sync).
      Also do you know which board type you have? And do you have access to an oscilloscope?
      aaablettt's Avatar
      is Happy
      Happy
      Apr 2013
      1,023
      15 Post(s)
      226 Post(s)
      Quote Originally Posted by crackedMagnet View Post
      Thanks for chipping in.
      This board set outputs a composite video so no sync wire at all. Just a ground and a video composite. I have swapped monitors and got the same issue then I swapped motherboards and issue ceased.
      No oscilloscope, just a logic probe.
      Jul 2017
      Wellington
      23
      10 Post(s)
      New Zealand
      Quote Originally Posted by aaablettt View Post
      Ah, right. Not sure exactly what board you've got, but if its the L shaped one I've had a look at the schematics and the first place I'd start looking is an 74LS55 IC named 6B on the schematic. Try the logic probe on pins 1-4 and 10-13 and see if any of them are stuck high or low. The output of that IC (pin 8) is marked as "Comp Blanking" so a reasonable place to start.
      I'm assuming aside from the vertical rolling the image is otherwise fine?
      aaablettt's Avatar
      is Happy
      Happy
      Apr 2013
      1,023
      15 Post(s)
      226 Post(s)
      Yes, the image is fine otherwise.
      I have probed around 4F and 6B. Nothing obvious but I'll go again.
      Cheers.
      taito's Avatar
      taito is offline
      is taito is good
      Geeky
      Dec 2009
      Melbourne
      471
      15 Post(s)
      69 Post(s)
      Hi Jimmy. What type of board is it?
      aaablettt's Avatar
      is Happy
      Happy
      Apr 2013
      1,023
      15 Post(s)
      226 Post(s)
      L shaped.
      aaablettt's Avatar
      is Happy
      Happy
      Apr 2013
      1,023
      15 Post(s)
      226 Post(s)
      Changed out the 10mf cap.
      Jul 2017
      Wellington
      23
      10 Post(s)
      New Zealand
      Did that fix it?
      If not... it looks like there are some lines that go high low at different frequencies. Some of the inputs to the blanking logic IC (6B) are these signals. Looks like they use the fact that they will all be high together at a certain interval (effectively dividing the lowest frequency by a 2^x number) to do some sort of timing. Checking those lines are pulsing at the right frequency would be helpful but i'm not sure how you can do that without a scope.
      taito's Avatar
      taito is offline
      is taito is good
      Geeky
      Dec 2009
      Melbourne
      471
      15 Post(s)
      69 Post(s)
      L shaped.
      How fast is the rolling? Annoyingly slow, fast flicker? I s the rolling consistent?
