• Enraged
  • Embarrased
  • Drunk
  • Down
  • Depressed
  • Crying
  • Crazy
  • Cool
  • Cocky
  • Bemused
  • Awesome
  • Annoyed
  • Angry
  • Amused
  • Friendly
  • Geeky
  • Godly
  • Happy
  • Hateful
  • Hungry
  • Innocent
  • Meh
  • Piratey
  • Poorly
  • Sad
  • Secret
  • Shy
  • Sneaky
  • Tired
  • Wtf
  • Page 1 of 4 123 ... LastLast
    Results 1 to 10 of 33
    Thread: Assembling a WPC089 MPU board from scratch
      Sabot68's Avatar
      Sabot68 is offline
      is warming up so it can kill you
      Dec 2013
      NSW
      84
      26 Post(s)
      HI all,
      I have set myself the task of building up a WPC089 MPU board, partly as a project and to have a spare MPU board for my Addams Family pin.
      While I have a basic understanding of electronic components (eg I can tell a diode from a resistor etc) and I am reasonably handy with a soldering iron (surface mount stuff still scares the carp outta me) this is by far the biggest project I have taken on.
      I received the bare board today and have assembled 95% of the components.
      My first question is... there are a bunch of pin outs labelled 'W' 1 through 9, on my bill of components these are described as 0 ohm jumpers, can I use the discarded legs of resistors for this or should the jumper be insulated wire?
      I suspect I will have may other questions as I go along so I ask for your help and patience....
      Andrew
      Homepin's Avatar
      Homepin is online now
      is hereby granted the status
      of.....TECHSPERT
      Secret
      Jan 2009
      Cairns
      12,868
      376 Post(s)
      3125 Post(s)
      Vatican
      Any piece of wire will do - be careful as not all of the "W" jumpers are used - check what RAM and ROM you will be using as this is what these "settings" are for.
      There might be something in here that answers some of your questions:
      http://homepin.com/kits/WPC_INFO.zip
      Gemini2544's Avatar
      Gemini2544 is offline
      is playing in the mancave.
      Amused
      Mar 2010
      Wimmera, Victoria
      4,525
      51 Post(s)
      1050 Post(s)
      Double check every solder joint because solder bridges are bad. And don't overheat the components with the iron. Good luck.
      c_mario is offline
      This user has no status.
      Jun 2013
      NSW
      238
      4 Post(s)
      73 Post(s)
      Quote Originally Posted by Sabot68 View Post
      HI all,
      Andrew
      You can actually buy 0 0hm resistors.
      http://au.rs-online.com/web/p/throug...stors/0188374/
      That's what was originally used, but wire links would be ok.
      Homepin's Avatar
      of.....TECHSPERT
      Secret
      Jan 2009
      Cairns
      12,868
      376 Post(s)
      3125 Post(s)
      Vatican
      Quote Originally Posted by c_mario View Post
      We supplied 0 ohm links in our kits but they aren't necessary. A piece of wire will do the same job.
      Sabot68's Avatar
      Sabot68 is offline
      Dec 2013
      NSW
      84
      26 Post(s)
      Thanks Again for all the help so far..
      Couple more issues I have.
      I have soldered all the resistors from the list of components on to the board, R76, R81, R99 are left empty.
      Also how can I tell which way the 3 reds leds are mounted, I know the long leg of the led is the positive but there is no polarity marking printed on the board. There is a trace on the board that is common to all three of the led holes so I assume the that is negative? (hole closest to the edge of the board?)
      and how to I mod the board to take a CR2450 battery and holder?
      Homepin's Avatar
      of.....TECHSPERT
      Secret
      Jan 2009
      Cairns
      12,868
      376 Post(s)
      3125 Post(s)
      Vatican
      What board are you building? A genuine one?
      The LEDs should have a flat on one side of the printed legend that indicates direction.
      Look at the schematic for the values of those resistors. I don't have it in front of me so I can't look at the moment.
      c_mario is offline
      Jun 2013
      NSW
      238
      4 Post(s)
      73 Post(s)
      WPC89
      R76 1k2 1/4w
      R81 1k2 1/4w
      R99 1meg 1/4w
      Sabot68's Avatar
      Sabot68 is offline
      Dec 2013
      NSW
      84
      26 Post(s)
      Supposed to be a NOS Williams board
      I have looked up the resistor values and they are R76 = 1.2k ohm, R81 1.2k ohm and R99 1M ohm.
      The leds I have do not have a flat side
      c_mario is offline
      Jun 2013
      NSW
      238
      4 Post(s)
      73 Post(s)
      Have a careful look at the very base of the led, there should be a flat section. The actual light emitting section is not flat sided, just the very base section.
