• Enraged
  • Embarrased
  • Drunk
  • Down
  • Depressed
  • Crying
  • Crazy
  • Cool
  • Cocky
  • Bemused
  • Awesome
  • Annoyed
  • Angry
  • Amused
  • Friendly
  • Geeky
  • Godly
  • Happy
  • Hateful
  • Hungry
  • Innocent
  • Meh
  • Piratey
  • Poorly
  • Sad
  • Secret
  • Shy
  • Sneaky
  • Tired
  • Wtf
  • Thanks Thanks:  0
    Page 2 of 2 FirstFirst 12
    Results 11 to 20 of 20
    Thread: Can't remove torx bolt
    1. #11
      sparkythepinmonkey's Avatar
      sparkythepinmonkey is offline sumatoboruki saru
      is stuck fixing everyones
      'too hard' jobs. Daijoubunai!
      Bemused
      Mar 2007
      South Australia
      427
      6 Post(s)
      33 Post(s)
      Quote Originally Posted by jason1 View Post
      Is it stainless into Alloy? if so thats the problem
      Yeah, could be galled to buggery.
      Chop it, drill it, re-tap it & start again.
    2. #12
      prktkljokr's Avatar
      prktkljokr is online now The New OLD 80's Operator
      is selling up
      Meh
      Apr 2008
      Atwell Perth
      2,848
      8 Post(s)
      112 Post(s)
      Tap a smaller multi hex socket over it so it is a tight fit, then use a ratchet to undo.
    3. #13
      Rich's Avatar
      Rich is offline
      is unable to sit still
      Hungry
      Dec 2010
      Victoria
      1,175
      37 Post(s)
      348 Post(s)
      i've tried 2 ways for these fu*kers
      1. I use a small flat blade screwdriver to go on the side of the raised centre into the two recesses
      2. Took ages as torx bit didn't have the hole in the socket for the middle bit, I drilled one into it.
    4. #14
      riverinapinball's Avatar
      riverinapinball is offline
      This user has no status.
      Friendly
      Jul 2011
      Junee , Near Wagga NSW
      435
      1 Post(s)
      64 Post(s)
      Use a cordless impact driver it will either come out or snap it off!
    5. #15
      Redback's Avatar
      Redback is offline
      is hmm, new field
      Amused
      Mar 2009
      Melbourne
      878
      4 Post(s)
      53 Post(s)
      +1
      Quote Originally Posted by robm View Post
      Vice grips?
      Sent from my SM-G930F using Tapatalk
      Good advise here,
      Red
    6. #16
      Autosteve is offline
      Dec 2016
      Barden Ridge NSW
      672
      18 Post(s)
      230 Post(s)
      Quote Originally Posted by Rich View Post
      If it is a true anti tamper torx bolt, (anti tamper is the style with the center pin), it will be hardened.
      Being hardened means it is hard but brittle.
      Get a center punch, aim it at the side of the center pin on about a 45 degree angle and a good quick hit on the punch with a hammer and the center pin snaps clean off.
      You will be surprised how easy it is to knock that center pin out using this method.
    7. #17
      Beavisbeaver is offline
      is is solving another problem
      with these damn games...
      Friendly
      Sep 2011
      Glenrowan, Victoria
      36
      3 Post(s)
      4 Post(s)
      Tried an impact screwdriver?
      Supercheap & Bunnings has cheap versions of them.
      My old man (mechanic) used to spray WD40 on the bolt then bang it with the impact screwdriver. Only seen maybe 2 out of hundreds that he ended up having to drill out...
    8. #18
      hotty's Avatar
      hotty is offline
      is Lucky Phil
      Jul 2009
      Victoria
      1,972
      82 Post(s)
      646 Post(s)
      Or use a torx in a battery drill with the clutch setting so it rattles the life out of it. Can usually break it down.
    9. #19
      Rich's Avatar
      Rich is offline
      Hungry
      Dec 2010
      Victoria
      1,175
      37 Post(s)
      348 Post(s)
      bit late for this thread but our local Aldi (Carrum Downs Vic) will have these for sale soon IMG_7386 (Custom).JPGIMG_7387 (Custom).JPGIMG_7388 (Custom).JPG
    10. #20
      Redback's Avatar
      Redback is offline
      is hmm, new field
      Amused
      Mar 2009
      Melbourne
      878
      4 Post(s)
      53 Post(s)
      The OP, hasn't been on since Apr 13th
      and hasn't responded to any of the comments.
      I'm guessing the screw has long been removed.
      Red
