• Enraged
  • Embarrased
  • Drunk
  • Down
  • Depressed
  • Crying
  • Crazy
  • Cool
  • Cocky
  • Bemused
  • Awesome
  • Annoyed
  • Angry
  • Amused
  • Friendly
  • Geeky
  • Godly
  • Happy
  • Hateful
  • Hungry
  • Innocent
  • Meh
  • Piratey
  • Poorly
  • Sad
  • Secret
  • Shy
  • Sneaky
  • Tired
  • Wtf
  • Thanks Thanks:  0
    Results 1 to 6 of 6
    Thread: Suddenly.....white screen
      Good Times's Avatar
      Good Times is offline
      This user has no status.
      Oct 2009
      Sydney
      85
      Hi, hoping someone can help. I'm using an iCade 60-in-1 which has been working fine. Just wheeled the cab a few metres and turned on. It was fine for a few mins, then this white lined screen.
      I've adjusted the screen/focus on my 20" Nanao to no avail. The icade seems fine as it's making the right sounds and I can navigate to a game and start it.
      The only thing I have noticed that may be an issue is this blue/white wire which may have pulled off from the transformer. There is one tab (the 12.6v one) that looks like at some point something was soldered to it. I'm hoping to get some guidance before soldering on and trying. And I wouldn't have thought a removed wire would cause this kind of symptom either.
      Homepin's Avatar
      Homepin is online now
      is hereby granted the status
      of.....TECHSPERT
      Secret
      Jan 2009
      Cairns
      12,422
      338 Post(s)
      2889 Post(s)
      Vatican
      Don't go randomly connecting wires - you WILL blow things up
      Good Times's Avatar
      Oct 2009
      Sydney
      85
      Ok good advice . Any ideas where to start troubleshooting?
      Edit- just traced that removed power wire and it goes to the coin slot (which isn't in use, so most likely purposely disconnected). I would welcome any other ideas - cheers.
      Good Times's Avatar
      Oct 2009
      Sydney
      85
      aaaaaaaaand chassis off to Jomac for inspection
      NEO-GEO Man's Avatar
      NEO-GEO Man is offline
      Happy
      Feb 2011
      QLD, Australia
      1,372
      22 Post(s)
      294 Post(s)
      Ukraine
      Quote Originally Posted by Homepin View Post
      Yep, and same goes for random pot adjustments.
      Check the sub board that goes to the chassis, and check the connections between chassis and neck board.
      Good Times's Avatar
      Oct 2009
      Sydney
      85
      Thanks guys. Don't worry I'm not doing anything random (that wire was connected at some point).
      I've cleaned each and every terminal with contact cleaner and still came up the same. Chassis on the way to Jomac, won't hurt to get a once-over in any case. The Jamma connector has seen better days, I might take the time to make a new loom for the machine whilst the chassis is away.
