BioBa Posted December 6, 2016 Share Posted December 6, 2016 Can some tell me if the lamps under the mini play field are #44 bayonet or #555 wedge? Link to comment Share on other sites More sharing options...
pinball_wizard Posted December 6, 2016 Share Posted December 6, 2016 Ok, now I may be wrong but I seem to remember them being leds on a board and not actual lamps?? Similar to how the newer pins are now sent out?? I'll see if I can confirm this. Either way, take it off if you don't get the right answer, it's pretty easy to do actually. Link to comment Share on other sites More sharing options...
Administrators furballx Posted December 6, 2016 Administrators Share Posted December 6, 2016 Probably the same question applies to Family Guy owners in case that helps you get an answer mate. I doubt they changed stuff like that when they re-themed it. Dave Link to comment Share on other sites More sharing options...
ItsUrFeminitzNYImNietYoma Posted December 6, 2016 Share Posted December 6, 2016 The shrek manual is here: https://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiklPnvxd7QAhUJerwKHUHSDhsQFggbMAA&url=http%3A%2F%2Fwww.sternpinball.com%2Fupload%2Fgames%2Fshrek%2Fshrek%2F438%2FShrek_Manual.pdf&usg=AFQjCNFEt1iInDJZ7kfEvhsg7flBPrnFuQ&sig2=4okUzu0Kf4V6inL_gnP1Jg, but it keeps crashing on me so you're going to have to find the right page yourself. Link to comment Share on other sites More sharing options...
BioBa Posted December 6, 2016 Author Share Posted December 6, 2016 You are right same machine as famile guy. According to the manual there is one #555 led under the mini playfield. I thought it was for the light between the mini flippers. But i don't know the type of all the other ones. Link to comment Share on other sites More sharing options...
djc Posted December 6, 2016 Share Posted December 6, 2016 You are right same machine as famile guy. According to the manual there is one #555 led under the mini playfield. I thought it was for the light between the mini flippers. But i don't know the type of all the other ones. I checked the Shrek manual and can only find that one as well, but it's down as a #44? Lamp 68. Link to comment Share on other sites More sharing options...
Michi Posted December 6, 2016 Share Posted December 6, 2016 Page 141 of the manual shows that there are LEDs on the mini-playfield board. 10 LED Amber Omron LA E65B, LEDP-LCC-4 5 LED White Omron LW 67C, LEDP-LCC-4 7 LED Yellow Omron LY E65B, LEDP-LCC-4 It looks like these are soldered on, not socketed. Michi. Link to comment Share on other sites More sharing options...
BioBa Posted December 6, 2016 Author Share Posted December 6, 2016 That solves the mystery. Thanks Michi and everybody else. Link to comment Share on other sites More sharing options...
maxi Posted December 6, 2016 Share Posted December 6, 2016 Yep I recently removed my mini playfield. They are hardwired Link to comment Share on other sites More sharing options...
