• Enraged
  • Embarrased
  • Drunk
  • Down
  • Depressed
  • Crying
  • Crazy
  • Cool
  • Cocky
  • Bemused
  • Awesome
  • Annoyed
  • Angry
  • Amused
  • Friendly
  • Geeky
  • Godly
  • Happy
  • Hateful
  • Hungry
  • Innocent
  • Meh
  • Piratey
  • Poorly
  • Sad
  • Secret
  • Shy
  • Sneaky
  • Tired
  • Wtf
  • Thanks Thanks:  0
    Results 1 to 4 of 4
    Thread: Karate Champ missing characters.
      Kaizen's Avatar
      Kaizen is offline
      is Defending against Invaders
      Meh
      Jun 2008
      Brisbane, QLD
      1,346
      111 Post(s)
      246 Post(s)
      I've had my Karate Champ running at home with no issues apart from losing background music, that was due to a faulty Programmable Sound Generator (both were replaced).
      I put it in the back of the ute and drove 10 mins down the road to where it will be sited.
      Plugged it in, switched it on and by the time I got around to playing it (an hour later) the two fighters were glitchy then finally disappeared.
      I brought the board home and plugged it into my test bench and left it running for a while, I came back and all characters were still fine.
      I checked the voltage at the board and it was sitting around 4.7v, when I adjusted the voltage up closer to 5.0v the two fighters disappeared, I dropped it back down and they reappeared.
      Seems this board doesn't like to run at 5.0v. and maybe the bumping during transit has inadvertently caused the +5.0v to creep a little higher, it was set bang on 5.0v when I had it running at home.
      I'll plug it back into the cab tomorrow and drop the +5v a tad.
      Womble's Avatar
      Womble is offline
      is The makers may make and the
      users may use, but the fixers
      must fix with but minimal
      clues
      Happy
      Oct 2007
      Melbourne
      5,259
      50 Post(s)
      315 Post(s)
      Hmm, where are you measuring the 5V?
      I've met PCBs that don't like what should be the right voltage, usually some IC is on its way out, can be a real pig to find the culprit.
      Kaizen's Avatar
      Kaizen is offline
      Meh
      Jun 2008
      Brisbane, QLD
      1,346
      111 Post(s)
      246 Post(s)
      I was getting the 4.7 at various ICs on the top board.
      I'll take another look at it with the voltage cranked up to where the characters just disappear and see if I can find any chips failing.
      Johns-Arcade's Avatar
      Johns-Arcade is offline My quest awaits!
      is a Homepin authorised parts
      stockist
      Meh
      Apr 2006
      SE Queensland
      3,617
      144 Post(s)
      682 Post(s)
      Quote Originally Posted by Kaizen View Post
      Let the PCB run for a few hours and see what happens.
      Regards,
      Johns-Arcade.
