Phoenix taito Cocktail instructions
Hi, Im trying to source the images for the instructions of a cocktail Phoenix machine. Is someone able to poit me in the right direction? Im also after the 'Coin Slot' image that's on an original Taito cocktail as I'm trying to replace my scratched glass top. Thanks in advance.
  • 4 weeks later...
  • 7 months later...
Also chasing this...any luck finding it? @R64
Possibly similar to this but in english.
There was also another image a bit like a game flyer that accompanied this on the left side of the glass.
http://i1038.photobucket.com/albums/a462/Kaizen088/Taito%20Phoenix%20Cocktail/TT%20Phoenix%20German_zpspd1nbxgd.jpg
http://i1038.photobucket.com/albums/a462/Kaizen088/Taito%20Phoenix%20Cocktail/Phoenix_arcade_zpslqpssosm.jpg
Edited by Kaizen
Oh hey, sorry I have actually been working on this. I found a great match for the font and I have been drawing this up in illustrator. I hit a snag with the Phoenix icons, I can use this stuff you posted.
Hey guys,
This is the card I'm working with - it was photocopied on the machine I have, I think someone just copied it from the original when they converted the Space Invaders.
I'm using the colour scheme from the above German card, as it matched the pics I've seen.
(Like this one, from a google search - check out the CP also.
[ATTACH=CONFIG]99812[/ATTACH]
Nearly done, won't be long. Its just finding the time..!
Hey guys,
[ATTACH=CONFIG]99811[/ATTACH]
@R64
See link below for PDF of Phoenix artwork done by Etienne.
https://drive.google.com/open?id=0Bzy5XMBV05xGVTY4ZjFNOWwyQXc
http://i1038.photobucket.com/albums/a462/Kaizen088/Instruction%20Cards/Phoenix%20Etienne_zpslcvua3n6.jpg
OK we're done!
So I spent quite a bit of time on this (when I probably should have been doing something else).
1200dpi from vector:
http://re-64.com/arcade/TaitoPhoenixInstruction%20Card(1200dpi)R64.tif
150dpi Thumbnail:
http://re-64.com/arcade/TaitoPhoenixInstruction%20Card(1200dpi)R64-thumb.jpg
I had to manually re-place all the S's as they weren't quite right in the font I found.
Etienne's PDF - thanks for that but it's not really accurate enough (I don't think he'll mind me saying that; he re-vectored my 600dpi Jailbreak CP stickers for his site).
Use it on one condition: you must post pics of it in your machine!
I will as soon as I get there. Pretty close...
Well done and great work.
Would you mind sharing the vector file so other instruction cards can be made.
I need to do one for my zunzun block and Lupin III tables
I'll tidy up the file and post when I can!
The tif should still be good for printing.
I got the instruction cards printed and fitted today.
The original artwork file size is 166mm x 93mm, the mask window on all my tables is 150mm x 90mm so I had to resize the image to 153mm x 93mm.
Also I noticed that the green is a nice bright colour on the thumbnail but is quite darker on the tif.
Looks great, will try to get the cab completed tonight.
http://i1038.photobucket.com/albums/a462/Kaizen088/Taito%20Phoenix%20Cocktail/20161022_163436_zpskqiapwsx.jpg
http://i1038.photobucket.com/albums/a462/Kaizen088/Taito%20Phoenix%20Cocktail/20161022_181234_zps0g1bdnpp.jpg
Edited by Kaizen
I've already scanned it but the panel is about 10mm too long to fit on a standard desktop scanner (it would need to be stitched).
I was going to try to find somewhere that can scan up to A3. I also have the Time Tunnel panels I'd like to scan as well, they are the same art as Jungle King.
Mark at inkjetlab.com.au in Brisbane has a 1.2 gigapixel scanning camera and copy strand that can do huge sizes if needed.
It's normally used for high end fine art duplication, but it would be perfect for all things Arcade/Pinball
I'll call Mark at Inkjetlab on Monday and see what he wants to scan each panel and also look at the Officeworks option.
I only have a P1 Phoenix panel though, not sure if anyone else on AA also has these panels that they could scan.
I'm sure there was a set on Gumtree in Qld that I missed out on recently.
Adam that's actually the cp you've got I bought it off the guy in Qld. I kept the bezel and sent the rest to you.[emoji6]
Trev
Adam,
I have a joystick for you but it's missing the pin that goes between the switches (should be an easy fix), the screws that hold the two parts together and the nut for the shaft.
Trevhttp://uploads.tapatalk-cdn.com/20161030/a23978282f48a0bb2d72ae35e4a2f472.jpg
It's yours if you want it.
Trev
